ITSAV6
It's my Granny's car!
- Nov 13, 2001
Stock pinion snubber? The extended snubbers sometimes unload the tires and cause spin. Use one of the online calculators to estimate converter slip. If you are driving over the converter more timing won't help. You can try the JD Hygard fluid and it could tighten the converter a little. Bump shift points to 5700 might help also by getting into the coupling rpm. Or just get Lonnie or Dave or Dusty to build you a 9.5 for your combo.
