SignUp Now!Originally posted by HighPSI
I have seen an average of 270 I and 220 E
I'm sure I must be mistaken It's a good thing I didn't say 284 Bill and Chris did the work. These are for Cometic intake gaskets with things moved around a little
Ted,
Are those ported to the FP1200 gasket or to the taller cometic?
Originally posted by Cheeseburger
I have a question, just because a head flows better on the bench have you seen a hp difference at the track?
I have read that some heads make more power then others (same brand) with lower flow numbers and everything else the same.
I think flow numbers are a guideline and maybe higher flow numbers does not automatically mean better heads.......true or false?
