NY Twin Turbo
All the good stuff.....Times 2.
- Dec 10, 2014
I would prefer to mount the tank in the trunk.
Do you have any pressure readings from the driver's seat?
I'm thinking the Bison spacer plate/spray bar looks interesting.
Is that your tranny cooler under the trunk?
I don't have an alky gauge in the car. I've got too many gauges already. And It wouldn't serve much of a purpose to be honest. The alky indicator light that comes with the kit is all you need. Also, when priming the system, you can feel the car stumble when the alky is ready to go. When you tune the system you tune it for a boost turn-on psi, a starting alky psi, and a ramping vs. boost ratio. Then after that, it does what it does. On my XFI data logs, the alky comes up so fast it would hardly make any sense to try to keep observing it while driving. More important, is to know that its there when you need it.
And yes, under my trunk, that is one of my two tranny coolers. The other one is up front where the stock intercooler scoop used to be.
