The quick answer is...How long do you want it to live?
The other quick answer is..."As much as you want as long as your fuel system (pump, pump wiring, injectors, supply/return lines, and filter) is capable of providing enough fuel and you don't ever let it detonate...ever!" We all know that is much easier said than done.
To be safe, I would say 15-16 psi with 93 octane gas and everything (plugs, wires, fuel pump, air filter, fuel filter, valve springs, timing, etc, etc, etc) right.
Conrad
