I have a stuck horn - when I turn my wheel it goes off. I've been trying to locate the three wire plug under the drivers side with no luck and trying to locate the horn under the hood with no luck either...I read it was located on the left front wheel area and see nothing, also nothing when I slide under the car...could it be somewhere else?
Is it possible to disconnect it from the wheel itself? Meaning if I unscrewed the center cap could I remove anything in there that would let me at least drive the car to get fixed without the horn going off the entire way?
