its EASY. Just - key off, depress the brake pedal 20-25 times [may be less], until the brake pedal becomes rock hard…. then just remove the old accumulator and replace the new one. You can put some clean brake fluid on the o-ring to lube it up. Tighten and check for leaks…. MAKE SURE KEY IS OFF! while replacing it.
aaron
