I'm using this engine for a hybrid
You're putting a GN engine in a Prius? Awesome
SignUp Now!I'm using this engine for a hybrid
Okay so u are doing the head gaskets ? Have you done a compression test on it ? I just think it would be a waste of time and money to have it out and not knowing the reason it came out to just slap it in another car . I'm betting the head gaskets are Toast and most likely the reason why the engine came out in the first place . Anyway seems like you will find out ether way just trying to let u know while it's a lot easier . Good luck .
How can I check if the head gaskets are bad?
Compression check will tell you.
What's the goal here? Do you want it in the car and running cheap, or do you want it in the car right and good for another thirty years?
At 80K miles, it's going to be nearly due for bearing service anyway. The service parts for these engines (bearings and gaskets) are still really cheap.
Pull the oil pan and a main cap.. I would just clean it up and run it
When you prime it i like to spin The motor over by hand alittle at a time. Also like to see oil come up to the rockers
  And you keep throwing pictures up that no one can tell you prob what you want to hear . O yea that thing looks mint I would run it .pull a cap off check out the bearings as stated  If they look good get a torque wrench and torque them back down to 100ft lbs . Also a compression test will tell you so much about a motors health I'm not just saying it because i want you to go through some unnecessary stuff bud .
 And you keep throwing pictures up that no one can tell you prob what you want to hear . O yea that thing looks mint I would run it .pull a cap off check out the bearings as stated  If they look good get a torque wrench and torque them back down to 100ft lbs . Also a compression test will tell you so much about a motors health I'm not just saying it because i want you to go through some unnecessary stuff bud .Even better .Leakdown test it after pulling a few caps
Yea you could end up like me yesterday when I pulled apart my motor . View attachment 302600 View attachment 302601 And you keep throwing pictures up that no one can tell you prob what you want to hear . O yea that thing looks mint I would run it .pull a cap off check out the bearings as stated If they look good get a torque wrench and torque them back down to 100ft lbs . Also a compression test will tell you so much about a motors health I'm not just saying it because i want you to go through some unnecessary stuff bud .
Clean the pickup screen, pull a cap or 2 and have a look. Once you see the bearings I'd run it
Okay, so I prime the motor today, oil did come out, of the push rods.. there was only was that hardly did. Once turning the motor by hand I was only able to do half turn then it became hard to spin didnt want to force anything. What can be the issue or what can I do? Should I wait till cracking with starter?
