- Feb 14, 2002
So if they allowed 80's cars to run in Factory Stock Appearing.... just how bad do you think Turbo Regals and TTA's would OWN that class?
SignUp Now!Yep, just another example of what Mr. Clark does for the auto world...
I think the rules would be prohibitive to us and keep us from being truly competitive. Internal engine modifications are not regulated but I believe they have to run stock exhaust manifolds and intakes. That would rule out bigger/modified intercoolers, turbos, MAF sensors, and probably ecu's and maybe injectors. IIRC there was also a discussion about fuel allowed and if boost could be changed. Now if mods were allowed to all those systems then we may have a shot at the title.
Sure would be sweet to see an 80's class allowed in the series... those FAST boys would find out what fast is all about.
I doubt they would be allowed unless they used the stock compressor backing plate/compressor housing and the Garrett .63 ex housing.New new Precision stock appearing turbo's would be a dead ringer for this.
Who has or maybe could even run in the 11's based on those current rules?Guys would be running mid 10's before you know it. And faster than their fastest before too long.
The thing they have that 99.9% of the guys on here dont is almost unlimited time for R&D and nearly unlimited funding. I can think of about one on here that could build a top notch competitive FAST TR. Id start with at least 10:1 CR, 260+cubes solid cammed and tons of different shock/spring/torque converter combos on a test car before i even tried it on a pristine original car. Mega $That would be a way fun project. Do it with a Limited to add insult to injury. Landau top, rocker trim, hood ornament, bench seat, column shift, alllllll that.
That is such a cool class though. Those guys got some trickery up their sleeves to make them run like that, on those tires, and still appear stock.
Bison,
Are you saying we couldn't make the power and we couldn't hook with them? The website shows the fastest Ford is only trapping 132. Seems like reasonable territory for a not-so-fancy 109 stroker motor with iron heads.
We should be able to hook to within at least a few tenths. Heck I can pull a 1.91 with 225 Eagle GTII's without even trying. The website shows their fastest Ford is pulling 1.6's with obvious massive weight transfer.
But yes we would need a "TA" series appearing turbo that could do it and that the rules would allow....
And think of the tricks we could pull using even the stock ECM... like less boost in 1st gear just to keep the tires from being torched on the launch, and speed density programming instead of using a real MAF...
