jayturbov6
- Feb 20, 2010
This is the setup that's on the car now.
pt-51
60 lb injectors
front mount
3"thdp
3200 stall
pt-51
60 lb injectors
front mount
3"thdp
3200 stall
SignUp Now!that right`!:biggrin:How big is you're wallet?
pt-51
60 lb injectors
front mount
3"thdp
3200 stall
my wallet is very smallHow big is you're wallet?
pt-51
60 lb injectors
front mount
3"thdp
3200 stall
the car runs 11.50's with a 1.5's-60'How quick (or slow) is the car currently? What will you tune with?
I use to tune with a direct scan but I will be tuning with a powerloggerHow quick (or slow) is the car currently? What will you tune with?
What tire height? Are you crossing the line in 3rd or 4th?boost - 26lbs
fuel- 45lbs vac line off
chip- joe lubrant
motor-only work done is springs and timing chain
I think the timing is set at 26
put a alcohol kit on it and crank up the boost..be sure to "tune","tune","tune"..
