Installing oil dipstick tube in stage II block
turboclam
It's hitting a rod/rod bolt. Can I just shorten it? Will the dipstick come in contact with the rod?
This is an 016 4.1 stage II, 3.625 6.350 rods.
Thanks!
I guess it could also be a splayed cap bolt? Just peeking through the dipstick hole.
Off the tube? Wouldn’t that send the stick deeper and get a wrong reading?
Mine was hitting on a 109 block with arp mains bolts installed.
I flipped the dip stick 180* and it didn’t hit anymore.
D
The tube has a stop on it so it doesn't matter if you cut the end off. Won't affect dipstick read.
Ok. Got it.
Mine was the stick itself and turning it 180° solved it.
This was on a 109 block.
The stick was hitting one of the main studs sticking out.
After trimming the tube, It may be worth bending the tip a bit to see if it helps, if it's still hitting. Mine had a small curve and it worked when I flipped it.
D
Yea I cut an inch off and it went right it. The dipstick also goes in pretty smooth. Thanks for the help.
