Although i am not a fan of the gear venders od unit or the the chrysler 518 overdrive transmissions,they are much more efficient when operating in overdrive than traditional gm units(2004r 4l80e) with an overdrive ratio planetary located in front of the compound planetary gearset.the gv and 518 have a rear mounted od planet located behind the compound planetary gearset.to produce overdrive output must be faster than input.if the planet is located in the front it takes more energy to overdrive the larger mass than if is located in the rear.viewing the input and output speeds of a 4l80e or late 518 (new model designation)on a scan tool will shine light on this "speed biasing".now the 700 is in a class all by itself.the front planet alone produces first gear,the rear [planet overdrives this ratio in second to produce second gear,third is direct drive and fourth is the rear planet overdriving direct drive.the aod,now that a whole different story,very efficient in first and second but lacking in third and fourth but still better than the traditional gm units
