Is this good??
WICKEDGN
I CANT LIVE WITHOUT BOOST
Well ijust got my turbo link and decided to make a littl e run at wot and this came up.( tps.3.96, 02. 773, int. 128, blm. 128. runnig rich, volts. 13.2, and i belive my ret.deg. were 1.2)and at park. idle weird my (tps. .71, blm. 121, int. 131, 02xcnt. 1 and my o2's jump around. is this bad or good
Zam70 i dont know what's IAC im gonna take a look at my run again thanx. they were. IAC 133 @ 53% cosntant then i let off is that good/bad
What is you MAF reading? Should be 254 or 255 depending on your chip.
O2s look pretty good at WOT.
ZAM70 is right. Your TPS is WAY off :eek:
At WOT I think your TPS should be around 4.44:confused:
Anybody confirm the TPS at WOT?
Alot of differing opinions on what WOT TPS should be...suffice it to say over 4.2 seems to be the consensus....
Regarding TPS WOT ask Bruce. :D
Anything over 4.0v is ok to him and some others.
Mine is .42 idle and 4.68WOT.
If you were to build an ecm bench you'd see it happens at about 3.4v.
Or use Lockers, and see when it reads 100% TPS.
The important thing is that the butterfly is wide open when the petal is mashed to the floor
Follow the procedure at gnttype.org for both the TPS and IAC and then see us in the morning:)
