ok guys i have decided on getting a nitrous kit for my 86 3.8 intercooled engine. i need to know everything there is to know about doing this. first ill start with everything that i have done. its a 3.8 not sure of miles on it, 2 1/2" hooker cat back, 1 1/2 stock IC's with modded neck, 62MM TB and upper plenum, AD power plate, stock turbo, stock injectors, reds XP plus in tank fuel pump, fuel pump hot wired, billet adjustable fuel pressure regualtor set at 45psi, thrasher 92 chip, K&N outside by front bumper, cr 43ts Delco plugs, jacobs wires, new valve springs, new timing chain, autometer boost guage, and i think that is all unless i think of more...... now my qyestions are how hard is it to put in??? is it the kind of system that you can just arm it then whe nyou take off hit the button and go??? can i use this chipo with it?? i know i need 45psi with this chiop is that too much?? what plugs should i use?? whats a good psi? i just wnat to run a 75 shot. car goes a 13.8 at 98 with a 2.4 60 foot due to bad tranny and no first gear. so im guessing its a 13.4ish car. let me here everyting that i need to kow so i dont go into this blindly. most of my freinds are runing it but no one has a turbo car....lol thanks for all that reply if i left anything out just ask me.
