Jimmys 2004r transmission
Reaper6
It's a Jimmy's transmission. Has been sitting around for about 3 years. I'm choosing to go a different route.
HDS Hardened Stator
Wide Alto Red Lined Band
Shift Kit
Transgo Pump Ring kit
10 Vain rotor (pump)
Line Pressure regulator spring
Alto Redline clutches
Looking for 750, no core.
Pickup only.
Interested.... has it ever been run??? Is it setup for lockup still??
Jeremy
Jeremy
Yes, it was in a running car for about for 1500 miles, the car ran mid 11's. Also yes, the car did a multi disc lock up convertor in it so it is a lock up setup.
This is a BRF tranny you know people are paying and asking $400 just for a good BRF core so it's like you're paying $350 for all the other stuff and labor that's in it.
HTH
Prasad
Yeah its not a bad price but getting a new trans from Jimmy's isn't much more... plus he'll do the install and ill know if something isn't right he will fix it... I'd rather spend the little more and have the peace of mind I think...
As long as it's his trans, he will charge you 300+ parts to fix it. He is as good as they get for customer service. I think his latest build like this one is around $1,200 and the all out one is $2,000.
Prasad
jimmys trans
will like to buy & pick up. VIKTOR. phone #708 953 1908 or send your #
yes, it was in a running car for about for 1500 miles, the car ran mid 11's. Also yes, the car did a multi disc lock up convertor in it so it is a lock up setup.
This is a brf tranny you know people are paying and asking $400 just for a good brf core so it's like you're paying $350 for all the other stuff and labor that's in it.
Hth
prasad
yep
Everyone wants this tranny but no one has the money. Someone should grab this!!!
TTMFT
Prasad
