I spent some money, and did without the car for 6 months but now it's almost where I want it. I have some questions I'm hoping someone can help me with. First off, I'll list what's done to the car... Precision P70 gtq Turbo, Stock intercooler w/ big neck, Campion ported iron heads, Comp cams Cam (don't know the grind, but Billy said it was radical.), ATR 3" down pipe w/ cutout, built up 200r4 trans. (hardend shaft;heavy duty clutches; shift kit, etc.) Vigilanty 4000 stall lockup converter, 95lb. injectors, Moser rearend w/ 3.73 gears, F.A.S.T. system, BFG drag radials. I think that's the important stuff to list. Billy tuned the car on the Dyno and and told me not to mess with the setup. It's putting out around 500HP. Well..... I took it to the track last weekend and here was my best time. 1/8 7.942. 60 ft. 2.079. 1/4 ET 11.951@124.08 mph....Boost at launch was about 5lbs. But check out the 60 foot. Seems high to me but the mph is haulin' a$$. When the car hits second it's like someone turned on the Nitrous. I'm not spinning tires. The car just seems sluggish off the line. NOW... for my questions..... Would installing a transbrake solve the problem? Allowing me to come off whith 10 of 15 lbs. of boost. How about a non-lockup converter? I read somewhere that a non-lockup will out accelerate a lock-up. OR.... is my problem elsewhere. I know the car is capable of much lower ET's. I just need to get it to launch harder. I've looked at other guys times on this board with the same MPH and they are in the 10's. What do you think guys?
