killer times thank for a good kit razor..video up soon
1985GN
Breaking parts
the video is on here elsewhere of the pass but i will put it up in the alky section as the pass was on hess 93 and meth.......10.10 at 137.5..video will be up later tongiht in here
Thats awesome.. Congrats.. cant wait for the vid :)
[YOUTUBE]http://www.youtube.com/watch?v=2lUiztMZIEo[/YOUTUBE] awesome run!!!!!!!!!! julio is a blessing to the buick world
Awesome Ryan! I can see the car is running real well now that you have the XFI. I know you can do better than a 1.6 60' though :cool:.... kind of looks like your rear susp unloaded a little right after the launch and the tires lost a little grip.... ill be expecting to see 9's next season out of you!
10.10 is awesome off the footbrake.
thanks for the video posting lpaulabbot....CMB there is more in her as the track was not prepped so that was leaving at a measley 4psi and spinning....she is still a little rich and no timing on 28psi
Im going to atco this saturday ryan, should be a great day....If you arent busy you should come!
Hoping to dip into the 10's with my tiny t63e :rolleyes:
Or blow up my 200r4 in the process!
109 block with forged internals
ported stock 8445 iron heads
ported intake and dog house
70mm TB
innovative dual ball bearing 70q trim
72's
ta style headers
precision FM
fast xfi
215/220 hydraulic roller
th350 with a 3200ish pats perf convertor
boost was at 28psi, timing at 21 and A/F around 10.9...she has a ton more in her still getting the hang of the XFI, next is playing with the timing and A/F to see where she likes at this boost then time to up it a little bit at a time to push the limits
hmm not really sure on that being as i have fast xfi in the car and it goes by different settings not by the gear
Was your timing at 21 in all 4 gears or just 3/4?
Th350 doesnt have overdrive :biggrin:
The XFI looks at MPH for timing pull, not gear...Its great because you can still run max timing in 3rd gear until that magic load point causes a little knock, and then you pull a bit out... can really stretch it out... every hundredth counts!!! ;)
My god Ryan, you are definetly going to be in the 9's. At that MPH you should be 9.7-9.8 :cool:. Launch a bit harder... theres 2 tenths off the traps, just in the tune you'll probably pull another tenth out..... hell, you already know this i dont have to tell you :D. Just saw a video of a turbo z28 run 9.86 @136.... :D
mph reads erractic on my car so it does not work anyway....yeah i still have some tweaking to do plus im going with a 3.5 bar map soon amongst other things....gonna lighten it up a bit before the cage goes in and then shoot for mid 1.4 60 foots and should be able to get a 9.6 or so at clsoe to 140 out of her....hmmmm then maybe a set of killer ported aluminum heads, lol
:D Im slowly getting there man.... LOL
Big plans this winter.... :biggrin:
BTW do you still have the rear bar?
yes still have teh bar, lol will you come get this thing already...ill be at the shop sunday afternoon into the night working on some stuff
