It can't prevent the knock from occurring in the first place
I understand that!!!! If it didnt detect knock, then how is it expected to retard it....
Clint
SignUp Now!It can't prevent the knock from occurring in the first place
Ian Whiteside
The engine was run with the unit for a season with no damage, then he sold the car and bought one with a Pectel ECU with internal knock control.Special Projects
Mercedes-Ilmor Ltd.
Quarry Road, Brixworth
Northants, NN6 9UB
Tel: +44 (0) 1604 880100 ext XXXX
Fax: +44 (0) 1604 883066
E-mail: xxxxxxxxxxxxxxxxxx
John,
I ran my engine on the dyno last week and was very pleased with the way your
Safeguard system worked.
Firstly I ran the engine on 98 RON pump fuel and mapped the spark advance to 2deg clear of detonation (as determined by the dyno knock sensing equipment) and ran some baseline power tests.
To calibrate the Safeguard, I ran the engine at low speed at borderline det and adjusted the Sensitivity pot until the LED was just starting to glow.
Next I added 2 degrees of spark to the map ( to take it to BLD ) and ran some power curves with the Safeguard active, these were around 4% up at the lower speeds where the engine is very det limited and about 2% up at max power. I ran some more curves at +4 and +6 deg from map but did not get any noticeable improvement over +2. The Safeguard was in Individual Mode, so I
guess you can determine that the cylinder to cylinder variation in det limit is low. During all this running, the dyno knock system never indicated anything more than occasional trace detonation.
I then ran some 102 RON fuel (the control fuel for my series) at map +4 and got similar results to the 98 RON fuel at this timing. However at map +6 with the new fuel, the improvements at the lower speeds were over 8% compared to the baseline figures.
Overall, I'm delighted with the way the Safeguard performed. It was simplicity itself to set-up, gave excellent performance gains and all this at a very affordable price. It is a fantastic product and I will be recommending to my friends (although not the ones in my race series) - I want to retain some performance advantage !!! ).
I sold the car a few weeks ago, I however had no problems with the
controller. When I was on the dyno, the operator seemed quite impressed but I wouldn't tell him what make the system was - the dyno was also used by an engine builder who builds most of the engines in my race series, so didn't want to give away my secret weapon!
Would this be more sensitive to false knock?
Eric:
The SafeGuard waits until the knocking cylinder is about to fire, then dials in the calculated amount of retard for THAT cylinder.
I have never had issues with any false knock and I run a loose gear drive for noise. This was exactly what Norbs had suggested to me on why the J&S was perfect for the situation and how I discovered the system. The sensitivity control allowed can really help with what engine noise is compare to true knock. And the sensitivity of the Bosch sensor is way better then the stock GN unit. All being said, if your concerned with piston slap then the J&S wouldn't do anything for you anyways because you probably can't tune if your allowing a motor to be that loose in the first place. While the unit may be easy enough for a amature to use... its definitely made for people searching for max performance.
Have a question for you. Where did you install the bosch injector?
Clint
this is quite interesting i turn knock control off after 4000rpm due to engine noise triggering it above that.my factory ecu (not a buick turbo ecu but still uses the maths above) cuts it off at 3600rpm stock.
What RPM does the Buick ECU ignore the sensor?
