Aluminum Kodiak turbo cover with the lettering "Turbo Trans Am"
These havent been available for a very long time. Made out of aluminum.. polishes really noce.
$300.00
Also have a chrome 4 inch MAF pipe that fits the TTA. Some minor scratches on the lower rear side.. but not visible when viewed mounted. Comes with K&N and 4 inch turbo coupler.
$250.00
Accufab polished 70MM TB and Precision polished plenum. Includes a polished block off plate for the vacuum accessories and a one inch Champion spacer drilled for the accessories. Polished billet FPR with -3 an fitting. And braided vacuum lines for FPR and MAP sensor. Selling it all as a one piece deal. Angle IAC boss included as well. No TPS, but linkages will be included.
$600.00
Champion ported intake, set of fully race ported 6702 TTA heads, set of Harland Sharp 1.7 roller rockers and Manley hardened pushrods for use with any hydraulic roller cam. Heads have fresh valve job and feature Ferrea valves. All work done by Champion.
$1600.00
Set of low mile TTA headers and crossover..
$600.00
TTA THDP Has been shortened to clear subframe connectors.
$900.00
Three large shaft turbo, a 66 qtrim BB, a TE64 and a TE63. all perfect. adds in forsale section.
Anyone need a 5 point bolt in rollbar, PTS full billet trans, stock built SG1 shortblock, fully built shortblock, random tech tq arm, 9 inch rear with 3.25/disc brakes, Denny's 4 inch driveshaft, boost controller (greddy profecb spec2), remote switching for boost controller, TTA front cover with oil cooler, etc etc etc..
She's going back to stock..
Grumpy has first dibs on the etc etc etc..
$300.00
$250.00
$600.00
$1600.00
$600.00
$900.00
