What is the conversion for Kpa to boost. My car was tuned on a dyno and the target a/f and spark advance all read in Kpa. I am trying to see at what boost the timing changes to 18 degrees max and the a/f goes to 11.2 They both occur at 178 Kpa. I assume you cant really tell by looking at these 2 charts where the boost actually reaches the 22lbs that was used on the dyno. Both the a/f and timing reach their max 18 degrees and 11.02 at 4700 rpm with a 4500 rpm stall They never go above this setting the reast of the way on the charts Thanks
