Tony Shoaff
- Apr 24, 2006
What is the best laptop to use with the powerlogger,translator pro set-up?? I keep having issues with port connection and recording stops during runs I am using a Dell Latitude.
SignUp Now!which lattitude?
You may be triggering some kind of hard disk protection (shock) protection.
PL logs into the windows memory, which can page to disk if you don't have a lot of RAM. I think Tunerpro logs to disk.
Bob
I use a low cost ACER laptom with upgraded memory to 1.5 Gig and Vista home, No problems at all. Hope this helps. Brad
does it stop recording powerlogger, tunerpro or both?
Bob
are you using a power cord for the laptop, or batteries?
What is the frame rate setting of PL?
what windows version?
Bob
Batteries
Frame Rate not sure where do I ck?
Windows XP Thanks
graph skip 0
logging 20 ??
