Last person to post will receive...
Status
Not open for further replies.
alky is on...20 psi no knock at all powerlogger is finally working...dead ECM at first....woo hoo
What will this combo run?
1989 TTA
60lbs
ported intake an heads-champion
ATR 3" exhaust
CAI
Erics chip and PAC alky
Walbro 340
Dutt neck TTA intercooler
214/214 cam-main caps
STOCK TURBO
1989 TTA
60lbs
ATR 3" exhaust
CAI
Walbro 340
STOCK TURBO
My TTA went 12.0s @ 114 with bluetops and stock IC, valve covers and intake never removed with the stock turbo.
If the TTA has champion heads, it needs a larger turbo for the perfect package.
It has potential to run mid 11s, but with the big cam and heads with the small turbo... probably 12.0 at 114 with a 1.75 sixty foot:confused:
Whose car is it?
BW
My car and yes I know the turbo is WAYYYYYYYYYYYY undersized...had a 63 but it was blowing oil. So I will see how far I can push the stocker. The car has gone 11.0's but has gone and going are two totally different things.
Jason
Stock turbo loves timing.
My white car is at 27° / 25° at 23psi of boost, im gonna add 1-2° more down low this spring.
With the alky and stock turbo, i suggest you keep the boost right at 22-23 and then start taking the timing up, see if the ET drops and MPH gains.
It ought to run pretty good with those heads and aerodynamics workin for ya!:biggrin:
Have you tried the e-brake launches in the TTA yet?
BW
I've tried. All I get is tire spin. These BFG's are worthless until about 50....By then it is time to let out.
Thanks for the tip about timing and boost. Say, where do you run at? I plan on going to KC this summer to run with Joe and his dad but you never know.
Jason
Jason
I race at the same track Joe and Papa Joe race at.
Papa lives about 7 minutes from me.
Joe Jr moved down south, about 45 minutes from us, and the track is 25 miles from my house.
Let us know if/when you decide to come to the track, the spring or fall would be alot cooler temp wise
Ebrake at the track:redface:
BW
winner
Well it would have to be in June/early july....how far is that track from 72758
215 miles from you to overland park.
If your going straight to the track, then it would be right at 190 miles for you guys.
Have you tried mokan yet?
BW
Status
