SignUp Now!it was a figure of speech.... fine it looks like the directs went through some kinda torture test. Better? Yes ive rebuilt stock trannys that looked pristine with high miles as well. Ive also fixed other builders mistakes in a tranny that looked pretty bad.
How many plates in the direct. Was a cause for the direct clutch wear determined? Were they sunburst or solid?
It does appear as though the direct are altos or some other red lined friction. That kind of throws your 'stock all the way through' statement out.
OD plate count should have been upgraded.
Pic of the direct pressure plate, please. Snap ring side.
Also. Still waiting for those pictures of the parts that look like they have over 200,000 miles on them.
It's slander unless you can prove it. No invoice is not good for your cause here. Not a good start.I do from Mike Kurtz, with a detailed account in the additional info box. I guess I took the buddy way of business for granted with Len, because I got nothing like that form him.
I don't mind any questions, I've tried and have been here to present my case clearly. I can't see it as slander, because it is not false of malicious.
My argument has a leg to stand on. Can't say the same for the other side. Some of these arguments based on nothing but faith in Len are feeble at best. I don't care about his overhead, if he can't cover his costs (which I am not implying is the case) he does not need to take it out of my a$$.
JD's experience, well, he has a good idea of what he is looking at and I think any other person who has built one of these would say the same.
And stop with the BS 200,000 mile comments
Well my memory stick is crapped out, and I can't get the last few pics. Basically it was a pic of a stock band anchor pin, and the steel that sat on top of the apply ring in the direct drum. The steel had a ring worn into it from the apply ring yet for some reason both sides were burnt and hot spotted.... hmmm. That tells me it was reused even though it was already hot spotted. The other pic was the receipt from Mike at Century stating his findings. It sucks they won't load so Disco is gonna have to scan it and post it if he wants to. Sorry John.
Thats how I read it also,I can't think that it had a good 2-3 shift at all if it burnt on 1 or 2 passes.Whoa there fella. You're side brought that up, and if I remember right, it was focused towards more than just the burnt frictions.
Mike's invoice isn't going to help you in court. You'd better shoot an invoice from Len. That is going to be the first item the judge asks for in court.
Im not making excuses for what you found,just curious how well it worked before he made full throttle runs with it.
I fully expected to be cross examined, doubted, debased, and smack talked. I have not come here to outwardly bash Len in an unwarranted fashion. I have stated my piece as plainly as possible. I took every recourse to avoid this. I have no problem presenting the pics, work order, and two other transmission builders accounts of this. It is what it is, and I did expect more of the other story by now. Which, like I said, I have been here everyday presenting my side. Awaiting rebuttal.
Sorry for you guys troubles!!
Its a real shame how quick other Buick people are quick to throw one of our own under the bus when they get burnt after spending big $$$$![]()
Heaven forbid a Buick vendor do somthing badWeve had pedophiles(Terry H),people who smoke crack(Dave S),and im sure people who are alot worse than either of those.Whys it so hard to beleive that a trans builder would only put the good parts where it was visible??
File a lawsuit AND report him to the IRS.My bet is that he,along with alot of other vendors whos sale are word of mouth via the internet,dont pay taxes.Post his business info on every website you can find.If someone ends up vandalizing his shop/livelihood,maybe hell think 2x before screwing another customer.
Here is a post from you (JDSfastGN) on page 2:
October 5th, 2008, 11:51 AM
JDSfastGN
Senior Member Join Date: Jun 2001
Trader Rating: (1)
I went and took a look at the parts that came out of this transmission, and like Disco Stu said, they were the worst ive seen. The tranny had a just a few passes and a little street time, yet the clutches for the direct (im assuming direct, if they were forwards then there was even a bigger issue) were down to metal. I have only seen one tranny ever had any clutches that were down to metal and that was a very high mile tranny and it was the low reverse clutches that had the issue. Even the ODs were burnt beyond belief and it never even saw a WOT shift into OD. Ill take some pics of the parts this week when i get back to Johns shop. The stock forward drum was cracked down the splines as well.
Then on this last page with this picture you state:
here is a stock forward drum, nothing special here (Thought it was cracked?!!)
