usetaboost
SAY CAR RAMROD!!
- May 4, 2005
Probably not the place for this but I figure I'm sure to get some info here. Picked up a 72 455 complete and th400 trans for probably a little too much money that needs a rebuild. Still has stock pistons. The motor sat out for a long time by the looks of it and took on some moisture in two cylinders. Dropped oil and didn't look too bad, didn't see much for water so that is good. The motor has obviously been apart since it had felpro gaskets. To me it looks like it had the wrong gasket in it. There's a hole in the lower section of the deck between two cylinders that is covered by the gasket. Thought that was odd.
