ttypewhite
- Oct 1, 2001
Check grounds, try another o2 and, try another injector harness, and lastly try another map sensor. Have you tried another ignition module?? There is a black wire (either 3 or 4th wire from the fire wall that is a ground) probe that wire and see if it is making a good ground. Mine wasn't years ago and I had to spice into it and run a ground wire to the body of the car. Been solid ever since. With these cars you can be chasing the simplest things due to their age. Their could be a break in a wire under the loom that can be causing your issues. Verify this line at the ecu and just before the ignition module shows it's getting a good ground.
