Jackie grabos
- Feb 2, 2011
I have an 87 gn. I just got a tt chip. Have a first gen maf translator v 5. I have jumpers set and wot set to zero. What should I have the other setting at idle set for? It was set to run 10% lean at idle. The other options are 10% rich or just a 3 inch maf sensor setting. It does not mention setting in tt chip instructions, it just says set acceding to your setup. Would a 10% rich setting at idle help prevent knock? The previous chip was last generation extenders chip. Thanks
