This all assumes that your initial tuning run is going to be at least close. What if it isn't? You can't know until after the run. I'd feel more comfortable seeing that the WB was at least trying to correct a miss tune issue with a heavy correction factor, rather than making the run with nothing to correct it until after the fact.
That is not the correct way to tune. Need to sneak up on the boost, check things along the way, read the plugs, check the data. Make sure that the fuel pressure is rising the proper amount. Then up the boost a bit and continue on.
The first thing I did when I tuned the '87 was to disconnect the waste gate rod. That limited boost to a max of 5 psi. Then just drove around using the auto VE Learn to get the drive-ability areas in line. Then moved into the boost areas and higher RPM and tweaked/checked/tuned those areas.
At this point I discovered fuel delivery issues, two of them. First was that the primary pump was weak, and second, not enough return line capacity. So the engine was leaning out just as it was entering boost, then went very rich once the secondary pump turned on.
Further testing showed that the secondary pump is good and strong, so pulled the fuse for the primary pump and run exclusively on the secondary pump. Fuel pressure is solid, further tuning can be be accomplished.
Then reconnected the WG rod and ran the boost reference line directly between the port on the turbo and the WG port. This limited boost to 18 psi. But, I also used the right foot to further limit boost, no slam the pedal and pray tuning here.
At this point continued up the boost & RPM ladder, checking, tuning along the way. I think I've been through 6 sets of plugs in the past year or so. This is due to various reasons, one being the PCV oiling down a couple of sets. Once that was fixed a fresh set of plugs was installed. Can't read them after they get covered in oil.
And using plain Autolite copper core plugs the cost is reasonable.
Once the boost/RPM tuning was good to 18 psi, the RJC boost valve went back on. Now at 24 psi and the tune is good. And the car is fun and I don't worry about it.
Now that the fueling is in line with reasonable SA, some testing/tuning of the SA can be done. Of course this is where it is easy to get greedy, as adding SA makes the car a whole lot more fun. But a bit too much and the head gaskets are no longer under the heads...
RemoveBeforeFlight
