Massive oil loss
Oil pressure may not be what's causing the leak. It could be slinging off the cam gear and out somewhere a gasket has failed or missed its mark. You may find nothing by priming it.
I hope so, when I started it with 7 quarts of oil in it, it squirted out from what appeared to be the oil pump housing facing the engine.
This is what I'm going to do. I was trying to do it yesterday, but my battery had died. I've gotten the PTE SLIC removed and I can almost see where I felt the oil leaking from. I need a dental mirror to make sure I can see. If it is leaking from the pump mating to the front cover, I would certainly like to know what caused it. My oil pressure on cold start was always at 80 psi and at hot idle 25 psi. I do know the pump was rebuilt with the engine rebuild, but it's not a high volume pump. Hopefully I will be able to take a look at it this evening. Hopefully it is some freak failure and I didn't hurt the bearing or the engine in general. If I toasted my engine, I'm probably going to rebuild with 3800 Series II. I already have a machined block, crank, main caps, heads and ARP hardware for the mains and heads.
that oil pressure seems awfully high. What weight oil are you using?
So a month later and progress?
I'm going to update today because I getting ready to pull the cap off the CAM sensor and set piston one at tdc on compression stroke. I hope it's easy to do.
Could that be the issue that caused the gasket/seal to pop?
Anyway i want to know if i have the CAM sensor positioned correctly to remove it. I took a picture with the cap off and a picture of the balancer where the 25* TDC are showing.
Ok found the leak dont know how it happened just yet. The stock oil pressure transducer is leaking through the prunges!!!### I'm hoping it was just a piece of crap defect. I hope it wasnt shrapnel through the oiling system that destroyed it. On the flip side I hope a $9 defective piece didnt ruin my motor.
Had the OPSU blow apart on an '82 Regal V6 on the highway way back when. replaced it, all was well:cool:
Only because I've had it happen to me. Glad he got it fixed. New doesn't always equal good/functional.
I believe the trust but verify is a way of life.
I've had a powermaster switch leak through the body so yes, those transducers can fail.
When i read your post, that failure mode went to the back of list. I said no way. Well i watched it squirt like something else!
