TurboSmart
- Nov 6, 2013
I recently replaced the headgasket. I used rjc stainless.
block had o rings and filled them with high temp epoxy.
Added water, started the car and idles quite rich...
but there is some sort of microbubbles on the radiator and there is a lot of filth.
oil doest not have water, no water vapor, at least visible.
I was thinking on adding some sealer tablets on the coolant but want to really do some diagnostic test before.
compression check?
Plug check?
Vaccumm is at 19 steady, even with a slight leak at injector 3.
Any ideas where to check?
compression check?
Plug check?
