86 t type,6157 turbo,msd 50s,tt 5.6 chip,hotwired tt supra pump,3" dp ported elbow,comp 260 cam,forge manual boost controller,rjc power plate,smc alky,speed pro forged pistons .30 over,mild homeported heads,pypes exhaust with testpipe,f body rad with ramchargers fan,3200 10" stall.Best run,7.39@91mph 1/8 mile 11.72 1/4 mile at 112 with a 1.57 60 foot on bfg drag radials.
I think I've stumbled across the problem:tongue:
I have more faith in Razors Kit.
MeanChicken... all the but kicking you do on the street, is that on alky or pump gas only. You can mix the C16 in but i dont know how well it will cover you against knock when mixed with 8 gallons of 91-93 octane. run it low as you can and if needed dump in the 116 to get you the rest of the way to the track. That is a better idea. then buy a couple more gallons there if needed. I wouldn't race it on less that 1/4 tank. Post the results please!
