Mock up done.......
InCharge-------no i have not tried it,,I think chuck has that same manifold and is further along then myself(have not had time in the garage)maybe he can help answer that
For the AC compressor, I think the smaller version of the Sanden will work w/ a custom brkt. I have the compressor, but have not gone further than holding it in place. Looks like it may work w/ the truck exh I have.
Am doing the frame. Then, will reassemble, and do the A/C brkt.
Here are some pics of the system, welded and installed.
Finish welded pieces 003.jpgDown pipe porn 001.jpgDown pipe porn 002.jpgDown pipe porn 003.jpgFinal design install 001.jpgFinal design install 002.jpg
I think I have a couple more w/ the muff in place..Still in the camera..will post them later.
I also added a flex coupler just after the split flange on the lower part of the down pipe. DP is 4"
that looks perfect Chuck what size pipe is the crossover ? also what year truck manifolds did you use or are they all the same ?
This is a 2.5" pipe. Lots of discussion on www.theturboforums.com, about the piping not needing to be more than 2", up to 1000FWHP.
Next time, [if there is one], will be 2".]
The manifolds are off an 07 Escalade. Not all are the same. The early 1's have EGR on them, and are "fugly".:D
where do you buy all of the stainless piping and what gauge are you using? what kind of rod did you use on the cast iron manifolds to weld stainless?
I got this from a friend's shop, scrap bin.
Lots of other places to get it:
Columbia River Bending
Ebay
Summit
Race Parts Solutions
Are a few I can recall.
This is 16ga, 304.
Welded the manifolds using 308 rod, Solarflux paste, [prevents sugaring], preheated w/ a MAP gas torch, cooled in a bucket of sand blast cabinet media.
Chuck you set up looks great !!!! Did you ever consider making these for people ?
I'm going to make some changes, then take the pipes to my bud's shop for a look see. [Random Technology].
We may have to have them digitized in order to do an exact fit. [CNC bender]
I am also looking at reducing the X over to 2.o / 2.25, from 2.5. 2.5 is plenty for 1000HP, and may not be the best for a street application.
I am thinking of doing a 5.3 ls single turbo on my 85 Monte SS . Will the 07 escalade manifolds work on a 5.3 ? I'm new to the LS stuff thanks
Yep, most all the truck engine manifolds will work.
I use only the later ones that don't have the EGR port on the casting.
