OK here we go.
now that I know your location, you should update your profile info... just so we can put a place to the name.
now, you want a turbo... but your not quite sure what it takes to get there.
OK, lets work with this.
so you got yourself a nice, clean, low milage non turbo car. its a great start.
we have a few options, lets take a look at them all to see where we go, I will try to be as realistic about total cost as possible.
first option,
we throw some mods at the engine you have first.
OK, we can get a better intake, a good set of headers, a better ignition curve and a solid carb. that should easily make a seat of the pants difference. I would say we could make all of these upgrades for under 700 dollars.
parts needed: Intake, Carb, Gaskets, distributor curve kit, and TIME.
2nd option.
we upgrade to a carb turbo system. now this is where it all begins to get kinda difficult. I will try to take it slow. OK, so first we need all of the parts to complete a carb turbo system (listed below) and we have to make the appropriate mods to the engine to make it stronger for the added power of the turbo. Now, most people are going to argue weather the pistons should be changed out in the motor to ones made just for turbo use, I myself prefer it but many have been very successful with the stock carburator pistons - you do some research and decide for yourself. here were looking at 1000 dollars to ensure correct and proper operation.
Parts needed: [required] Intake, turbo assembly, turbo brackets, L/R exhaust manifolds, cross-over, up pipe, down pipe, boost refrenced carb, boost gauge, 5pin HEI distributor and ESC box (can be substituted for MSD BTM6) , and gaskets.
Optional parts: turbo pistons, camshaft.
3rd option,
Blow Thru Carb. This is the setup I like to call "BANG FOR YOUR BUCK" because this is probably the cheepest real fast system out there. Its relatively easy to set up and find parts for, but does require some tuning knowledge. this time around, you would get to use the intercooler like the 86/87 cars and probably make just as much power. Again, pistons, cam are things that are highly reccomended specially for the novice to boost tuning. I would honestly think this could all be easily done for 2000 bucks if your smart.
Parts needed: [required] 4bbl intake, carb hat, boost reference fuel regulator, 86/87 L/R exhaust manifolds, crossover, down-pipe 86/87 turbo, either build or buy a blow through carb, 5pin HEI distributor and ESC box (can be substituted for MSD BTM6) , Boost gauge and gaskets.
Optional parts: turbo pistons, camshaft, intercooler, alky kit.
4th option,
86/87 GN SFI. This is the stock turbo system for the last of the GNs, while a great in operation system, it will require alot of work and time (did I forget money) to swap one of these systems.
Parts..... well there almost too many to list, and so I wont. Your best bet is to find a car to swap the system out. its almost way to hard to piece it together otherwise, even for a seasoned vet. 1500+ + + + depending on how you choose to do the swap.
does this kinda help any?
A.j.
