87GN 98GTP
Andrew
- May 29, 2008
As I stated in a previous post weber racing built my motor and totally did not do it right with leaky heads, loose timing chain and mains a few loose. So now im at the track turned the boost up and the car falls on its face(didnt push it on the dyno). Get the facts from Weber with specs and had the 224 224 cam grinded to make sure its all good (it is a billet) and find out the lifters that were put in were hydrolic and cam requires solid and the springs are not the correct poundage. At this point im so mad spending LOTS of money to have then build a motor with half the stuff wrong
