CamoDeafie
- Jan 7, 2010
depending on the piston and crank combo; somewhere from 10-11 to 12s
SignUp Now!depending on the piston and crank combo; somewhere from 10-11 to 12s
Easiest thing to do is to contact a piston manufacturer and have them made the way you want. A 11 to 1 compression will give you what you want and you'll be able to have the clearance cut for the valves that you will need. If you use off the shelf pistons you may have some clearance issues and bend a valve.
wouldnt it depend on if the pistons are forged or hyperteutic ? I mean; maybe can start with the basic LN7 dished 3.0 piston set then cut reliefs for valve and still maintain reasonable comp if its same comp height as older 3.8 (1.805 comp height) ?
those blobs arent welds they are SILICONE!took some new pics of the rust on the car today to many to post so go on the album and check it out but i will share these with you
my car pictures by futten - Photobucket
