TexasT
Texas, Where are you from
- Sep 10, 2002
Anyone have a source for the correct pwr steering pump? Mine has 150k or so not needing one yet but I'm sure there will come a need.
SignUp Now!Mines got 169+ still works great. Actually love how the car turns. its very tight turning radiusAnyone have a source for the correct pwr steering pump? Mine has 150k or so not needing one yet but I'm sure there will come a need.
Only time I've had good success with vacuum brakes has been in my current NA el Camino. They work good. I installed a hydroboost setup in a pro touring style Camaro...bad ass. Neck snapping stopping.
I've installed vacuum brakes on a couple other NA cars, worked great.
I converted another 87 GN to vacuum, brakes were more dependable than the PM but sucked in comparison to hydroboost. Two of my buddies with GN's as we speak, have the worst brakes ever. Both going to hydroboost. I have hydroboost in my GN and look forward to good stopping power. There is a reason most if not all heavy duty trucks come with hydroboost. The shit works. If your pump can't handle running the brakes, it is probably on the way out anyways.
Sorry Earl, I can't agree on this one
I've done way too many brake setups and have found what works best for me. To each their own.
OP, whatever you do, be sure to change the proportioning valve if it's cast iron.
You could very well be right.The only reason vacuum brakes would suck on GN conversion is because you used wrong master cylinder , been there ,done that .
You mean to the braided stainless ones ?I had my power master fail and I did the conversion to vacuum and never looked back . I have had Gn vacuum brakes and that is what I stayed with
Before you do anything change your brake lines . They are what caused the failure in the first place .
If I may digress this topic regarding brakes takes me back to '83. The brakes failed on my Mazda GLC as I was braking for a underpass light, balls in throat and went between lanes of stopped cars. Finally bumped into a 1970's Chevy P/U who actually allowed me follow him too my home just a few miles up the road, good times.
