They say a picture is worth a thousand words so I thought I'd post a few vs. post about the setup. It's obvious what I did and to anyone that has done a full E85 conversion it's obvious how well it runs, car feels MUCH faster and I can't wait to throw it on the dyno just to see what this little TE60 will do with E85. Motor is essentially stock and I am sure pretty tired with 99K on it but we'll see how long it holds together before I have to yank it and put on my GN1 heads, cam and intake and a new set of rotating parts etc.
E85 is cheap, ZERO detonation at 31psi but I turned it "down" to 28 to be safe!
** Update 1/7/16 **
Friends, I no longer own my Turbo Buick but I want to keep helping you guys where I can. I've shared the album of pictures on FB to Public here is the link: https://www.facebook.com/media/set/?set=a.435996643110115.92510.100000993492856&type=1&l=9d7e7d960a
E85 does introduce a few challenges:
Run a PCV it will collect water when it's cold out, don't freak out, empty it often
Change the Oil every 3K miles or 3 months, blow by of E85 is hard on the oil
If you don't have flex fuel, clean your injectors with an injector cleaner...after about 5k miles the injector tips will get nasty. A clogged injector was the cause of the death of my stock motor, in hindsight i would have run a bottle of injector cleaner every other E85 tank. Good luck and have fun.
** Update 1/7/16 **
