Went to the local track tonight. It was about high 40's tonight. Finally broke into the 11's with my alcohol and 93 pump gas combo. Ran a 11.99 @ 110 mph w/ a 1.63 short time. Car ran 12.0 twice and 12.1 also on the first passes. This is with the dual nozzle progressive SMC kit. The car has ALOT more left in it because I was only running 23 lbs of boost. At first I had the pump speed on 8 and it seemed to slow the car down on the top end. Turned it down to 6 and picked up about a tenth and 1 mph no other changes same 1.63 sixty foot. Still had no knock at all the entire run on pump speed 6.
In case nobody knows, my car is a full weight GN with ALL options, weighs about 3800 with me in it, heavy stock wheels with slicks, bone stock motor with about 105k miles, and a 22 degree timing custom chip from Joe L.
Just thought I would share...met some cool guys there too like Surge (DR BOOST) and Lemant...couple guys with 71 and 74 GTQ turbo/stock block combos...had a good time!
