Been fighting breakup at 16-18lbs boost.....I changed my set up from a max effort 16 POS thumbwheel running 50lb injectors to the Zo6 85MM MAF & basiuc translator along with Big Mouth cold air intake and 3.5" Intake pipe..Running Julio's alky kit at 5.5 on dial
Car seems to be running lean and the TT chip is still trying to add fuel..with all these new parts. Here is a run ( Zip File) that I was going thru and flooring it to WOT and then letting off -still sputtering at full boost...any inputs from the log attached
FYI-I just replaced
1. Fuel Pump-New Racetronix
2. Fuel Filter-GM
3. Billet Regulator from Gbody parts-4lbs line off
4. Turbo Tweak Alky 6.0 W/B Correction chip
5. Fresh Plugs Gapped at tight .32
FYI-I just replaced
2. Fuel Filter-GM
