SignUp Now!I have been wanting to mount stuff behind the glove box and notice you have done it a few times…. Are you able to drill into the black plastic or are you mounting stuff some other way. I have been contemplating drilling into the plastic and mounting a piece of black ABS which will be my surface to attach things but am not sure what is on the other side
Gotcha.... No A/C ducting.... Explains it. ThanksThe plate I use on the back of the door comes from gns performance.
With the AC ductwork gone it is a large open space behind the door.
I made a sheet metal plate for the msd box to mount on. It uses two of the door mounting holes and clips in a tab on firewall behind dash.
I had a plate mounted vertical, I screwed it to the metal cross piece that the door mounts to.
I made that bracket, the arms are 1 inch longer than stock to get around the Champion spacer, and shaped for the coil.
