SignUp Now!the knock sensor only reports knock at certain frequencies. There's no point in speculating anymore. Tear it down and see what you findYou would think that would set the knock detector off with that type of force. No?
Im gonna pull it and inspect everything... Meanwhile, getting a cage and if I have a worse case scenario, then im going the TA route.
Just hard to believe that a block that was professionally gone through would only last to the mid high 10's and break.
Im not ruling it out, but I will know for sure and update everyone.
Thanks guys
As these car get older, new and weird issues are happening that we have never seen, and some, like yours defy the common logic to solve.
Reading through the entire thread again and all the items you have examined and checked bring me to a point of what would be my next move?
Since you have an off-and on-again issue with oil pressure, before I would pull the engine, replacing the timing cover/oil pump would determine if something is amiss with the cover like a crack or something worn out.
At least this would determine if is an internal engine/block issue or not.
If you do not have a spare cover/pump, I will be glad to loan you a known good one if you decide to go that route.
U say it's a stroker 109 , I'am not a expert but I have read where they will sleeve the oil galleries after the block is clearanced for the stroker assy , not sure if this apply's to your build if so you might have a look at it![]()
