My background on turning wrenches includes single handedly r&ring a TR motor back in '02. I've also installed a T-5 Trans in a 240Z (hybrid project with a 327 V8) with a custom slave cylinder and clutch around the same time. So I've got sufficient mechanical capability when I put my mind to it...is my point.
I've also done lots of the other bolt-on stuff throughout the years on TRs...injectors, turbos, exhaust, etc.
But I've never r&r'ed a cam, so this would be a first. I've spent the last couple hours browsing youtube on how-to vids for cam installs. I've found several on flat tappet cams, and that looks pretty straight forward...those don't intimidate me a bit. Unfortunately, I haven't found any vids on a roller cam install of any value. I've also searched extensively on this forum on roller cam installs, and that's where I do get intimidated. I'm reading some foreign terms like "cam thrust" and "dial indicator".
Right now, the heads are off the car (the state where the former mechanic left it, and I'd be attempting to pick up the project). I've got the roller cam kit and roller rockers on their way from Cotton's coming in early next week. I've also got a pushrod length checker on the way from Summit.
So, I'm up for it, if folks are willing to guide me through it with patience and tolerance of a roller cam installer newbee.
I'd also like tips on what tools I should go purchase. I only have basic tools. I'll definitely need to go buy a torque wrench and I suspect feeler gauges. I have the option of having a mechanic install the upgraded valve springs on the Champion Irons for $100, or...can I rent a valve spring install kit at Advance Auto and do those myself?
But again, my main concern is the cam install itself, the sequence of the install (since the heads are now off), measuring the pushrod length, and the obvious...doing it right the first time.
So whose done a Comp roller cam and roller rockers install that's willing to guide me through this with patience?
