turbodave231
Moderator
 - May 24, 2001
I've disassembled many turbo without too many problems. I've gotten pretty good at getting the bolts to break free without breaking off. Heat, Wax, and penetrating oils seem to work to free the stuck bolts.
I have two different turbos where I cannot remove the turbine housing from the center section. In both cases, the bolts are all removed and the center section is free from the turbine housing. There is a metal "cup" that sits between the turbine wheel and the center section that is stuck in the turbine housing.
How do I get this "cup" shaped metal part to let go of the turbine housing?????
I have been soaking both alternately with WD-40, and a 50/50 AFT-acetone mix. I am trying to be patient and don't want to screw up a good turbine wheel or center section.
Anybody have any magic or advice?
Dave
Dave
