Need Help Still Got Knock
no its doesnt. i looks as if everything is good. you roll into the throttle and the WB gets richer.
brent go to post 5 dl the program or just open it and then load my file.
i was just looking at some of the logs and it looks like its not getting enough fuel at 4.1 pounds of boost with the turbo hooked up the a/f was .6 leaner then when it wasnt @ 4.1 hooked up and the EGT where alot lower when it was unhooked thus from being richer. i could be wrong.
eric is overnighting me a chip so we will see sat night.
If you take a paper clip and jump A&B on the ALDL it will add 15 degrees of timing. Get your timing light out and check if its at the factory 15 degree mark. Just to eliminate one problem. Eric Marshall told me that on an 87.
i will check that if all else fails. as of right now i just got off the phone with eric it looks like he is going to be able to come threw for me. THANKS ERIC he is going to over night me a chip it should be here friday by 1:30. :) eric said there was just to much timing at part throttle :eek: he added fuel and pulled some timing. he also couldnt believe how hot the inlet air temp gets in the intake. well looks good going to get some C16 tomorrow.
brent
nooooooooo !!!
this is a buick meet ,.....
bring the buick , !!!!!!!!!!!!!!!!!!!!!!
Reply
What underboost is saying the 15 degree mark is a test reference enabling to check for perhaps a slipped pulley & timing accuracy.The complaint seems to be centered on that possibility.One of Erics chips is also a step in the right direction.
o **** boys Boost231 is back in Action THANKS ERIC it was worth every penny to ship it next day.
Brent
so you happy now?
glad you got it together, so .............. 11's??
its only 6 days!!!!!!!
is it time to go yet??
oh yea, this is gonna be fun!
