ok guys i need your help, im lost. i got my turbo back today and got it on a few hours ago took it out for a drive to make sure all was good but nope still got knock. im open to all and any help. i have 3 power logger files attached. the first run was no changes to my chip before the rebuild at the end of the file last pull i held the test button on the alky to see if that would help. second run i figured with the new heads and the good flowing motor i needed more fuel so i added max fuel also at the end of the file i held the test button while i was getting on it. 3rd was a little power break in front of the house but it started to spin the tires since the air pressure is to high the the tires. the car pulls good under no boost and if i rev. it in park i get no knock. the car doesnt break up and it acts fine. no oil in coolant and no coolant in oil good oil pressure good coolant temp. please help or the car isnt going to make the WCN. should i order a new chip. could it be off that much over the old motor. well the second drive wont upload its to big of a file
as far as the powerlogger i have WB, IAT, IAT in the intake, EGT, ect. maybe i should lean it out? also could a crank sensor not set right cause this. when i pulled the plugs before the turbo they looked fine but i can pull them again.
