This is a line lock that I purchased for the Buick but instead decided to go a different route. The line lock is new and has never been hooked up and has never had any fluid ran thru it.
With the line lock comes 2 pre bent lines. I was going to install this near the proportioning valve on the bracket that mounts to the proportioning valve that alows the rod that goes to the steering column assy to pivot. The lines are bent to where you run the bottom line to the the bottom of the proportioning valve, then you cap off the top and run the brake lines to the tee fitting. This is the NHRA legal way of running a line lock.
Also included are the 90 degree fittings, mounting bolts, switch, switch holder, indicator lamp, fuse holder. Everything here is new, ready to install.
Asking $60 shipped anywhere in the lower 48 states. If paying by Paypal please add 4%.
