turbo john FL
ITS ONLY A SIX SHOOTER
- Dec 30, 2002
hey guys i had that other post up about car not starting after rebuild " new motor no start "" i have narrowed my problem too this . i have spark , i have fuel and the gen 2 is set up correctly . i have found unless im really dumb that my problem has been no compresssion do to the adjustment of my lifters .. i am running full roller with a 215/ 220 stick the lifters are com cam 853 s i installed and when i preload these from tdc on both valves per cyllinder i am spinning pushrod by hand until it no longer spins freely then i tigthen the adjuster 3/4 of a turn . by doing this i have no compression in any cylinders until i back off the adjusters to be free of any bind against the pushrod ( pushrod spins freely ) then i have compression in cylinder . am i wrong with the preload im trying to put on these lifters ?? all help is gratefully needed
