Just got my DS in today. 1st run.....
top of first:
4950 RPM
4.72V TPS
254 LV8
230 MAF
108 IAC
25.59 Inj PW
25 deg spark advance
0.7 Knock Ret
5 Knock Count
A/F 1.4:1 ????
02 volts 839 mV
02 x counts 87
BLM 142
INT 132
What do you make of it?
Next run......
near the top of third..... car cuts out....and pics back up almost instrantly....
according to datalog....
@ 92 mph .... TPS value went to 0.08
MPh went to 4mph
RPM went to 50 RPM
Knock was at 4
o2's went to 16 mV...
What in the hell is that?
all this happened in .05 seconds
.06 seconds later
TPS 4.72 volts
RPM and speed were still down but coming up
less than 1 second later.... speed was back up to 84 mph
just before car cut out....
text screen shows
PE Mode
BOOST
3rd
TCC
BATT
Closed Loop ?????
during that portion of 1 second:
PE mode went off
Boost went off
3rd was still lit.... but so is 4th?
Batt and A/C lit.....
Now it shows open loop for the first time??????
less than 1/4 second later.... goes back to closed loop......
Any ideas?
Why would it remain in closed loop when the pedal is on the floor?
top of first:
4950 RPM
4.72V TPS
254 LV8
230 MAF
108 IAC
25.59 Inj PW
0.7 Knock Ret
5 Knock Count
A/F 1.4:1 ????
02 volts 839 mV
02 x counts 87
BLM 142
INT 132
Next run......
MPh went to 4mph
RPM went to 50 RPM
Knock was at 4
.06 seconds later
TPS 4.72 volts
text screen shows
PE Mode
BOOST
3rd
TCC
BATT
Closed Loop ?????
PE mode went off
Boost went off
Any ideas?
