I have a new rebuilt transmission and followed all the directions to break it in. I'm using dextron 6 fluid and had the tv cable adjusted by pressure gauge. I drove it for maybe 150 miles before my first wot shift. With shifter in drive or in OD at wot it shifts good from 1/2 but I can't get it to go into 3rd it sounds like its hitting a rev limiter around 6k my knock gauge lights up and when I let off the gas it shifts.
Also when I try to shift manually at just normal driving it will not go into second when manully shifting from 1 to 2 until I shift into drive as if the linkage was off, so I checked it and even adjusted again and the same thing happens. Also only when I'm manually in 1st I hear a whinning noise when going slow, and no noise when shifter is in another gear when rolling in 1st. At normal driving with shifter in od it seems to be alright it shifts firm into 2 and when it goes into 3 you kinda don't notice the shift and in od you can notice the rpms dropping. I have a new 2800 converter also.
Do I need to keep adjusting the tv cable to get the wot shift to 3 or is it the transmission itself? Thanks.
