SignUp Now!so what do i do since i just bought xfi, is there an upgrade? or is this just like a flash?
Hey Cal,
What is the advantage of the 3 step feature over the 2 step and additional trans-brake options? Thanks
Datar
All right, here's the scoop. If you are upgrading to traction control or an internal logger, you will get the software upgrade for free. If you just want the software upgrade it will cost $49.95. If you want to send your ecu in for the upgrade with a new enclosure, it will cost $99.95 In order to do this. For those wanting to do this, I will need your ecu serial # Although, I have a database with serial #'s for most of the ecu's I have sold, I will still want your ecu serial # to be safe.
So this is an additional upgrade to the beta flash correcting the voltage, ESC, etc. from a while back?
Are you saying they will upgrade the box to traction control along with the software upgrade for $99.95? The traction control is just a software thing anyway - correct?
as far as the box upgrade, if that's true thats a deal. 99.95 for the TC :biggrin:
What have they improved on the TC
