SignUp Now!I have been too lazy to change the HG
Maybe in the spring I’ll get to the HG.
the intake manifold gasket went bad in my brothers GTP at 39K miles, and mine started to leak at 75K miles.
they've changed to an aluminum gasket, so when you buy new ones ask for a 2004+ grand prix. if you get the plastic gaskets avoid using dexcool, as it seems to be the culprit.
is there anything else i need from the 2004 application besides the intake manifold gasket?
Do i need to modify the the 2004 gasket in any way?
And as far as the SC gasket do i use the 2001 (year of my car) or one for the 2004 year application?
thanks
nope the lower intake gaskets are a direct fit....its the same gasket, just different material
you'll need the supercharger gasket for your year (gen 3 m90)
