With the air rushing in there it must be enough force to bind it up the last thing that you want is to twist a shaft off or have a blade hit and send metal through your oiling system and trash your bearing in your crank
no I meant when your driving down the road the fresh air throw your air filter
what air rushing?
The boost tester air?
Perhaps.
But it was "stuck" like that before I ran my boost tests.
I set my air regulator to 25 psi.
Now I grant you - the inlet bell and turbine never see 25 psi of pressure.
But not seeing how it does any damage.
although - I've been wrong before.
Filters all the oil 100%
I meant the air rushing into the inducer wheel(while your driving) forcing it back into the thrust bearing causing it to bind
Sounds bad...lol.
But I'm not seeing anything of that sort that would lend me to believe that was a probability.
I'd have to tear a unit apart - but it seems to me that if a blade shot off - it is either on the turbine side and is going in the exhaust passage or on the compressor side and is going to the air inlet (to IC).
None of which would be good - but ...anyway...
I've had 3 of these cars over the last 20 years I've had my share of turbo problems then the thrust bearing starts to get chewed up it sends that brass threw the center cartage and rite into the oiling system and the in and out play becomes greater causing the blades to hit the housing also sending debris into the center cartage and into the oil I've had that happen and also had a shaft twist so it can happen
If you have a stock working turbo, throw it in and eliminate the 49.
Can you push on the compressor shaft and spin the turbine, pull the shaft and spin, push to left spin, right spin. Cover all axis.
This is strangely one of the oddest issues I have read about in a long time. You have been very thorough in diagnosis and have explained everything very well. Now you have me scratching my head.
I would pull it. Slap the old one on and see what happens. I'm pulling for you man!
Nice We4
Take the cat off and drive it. With all the fart cans driving around you won't be noticed....until you put your foot in it .
I've used a lot less than 35 psi to spin a big ass holset from a Detroit without issue and that turbo was 25 years older than yours. You are on the right track. You WILL get this figured out.
